ZF 4HP22 fitting
Hello all. I'm working on a ZF 4HP22 transmission and have run into a snag getting one part. Its the fitting that comes out of the trans for the upper cooling line. The fitting screws into the trans is 18 x 1.5 mm. Then the coolant line screws onto that which is also 18 X 1.5mm. The Stücklistennummer on the trans is 1043 010 496 and the serial number is 0853680. Any help would be greatly appreciated. Thanks, Jack
No problem but if you knew what models of Jaguar used this transmission I can look it up in the electronic parts catalog to see if maybe Jaguar offers that part separately.
I do have one suggestion?
I like and use this place and all they do is ZF stuff. I would be willing to bet they would have an answer for you?
You did not post where your at so I not sure this will work for you as they are in the US?
ZF Parts
Klaus use to be easy to talk to but I have heard that they prefer E-Mail over phone calls?
Now you do have an older 4 speed version and The CTSC web site shows stuff for the 5,6 and 8 speed versions. So I am not sure how many 4 speed parts they have?
ZF Parts
Well I finally found the fitting I needed. The aftermarket BMW sites were no help. Countless emails to ZF were no help since the trans is so old and they said it was a BMW part anyway. Three trips to the dealer were no help either. To add insult to injury all the fittings I ordered had to come from Germany so probably 2 months wasted waiting on the wrong part. I finally found it on ebay. Its from Adaptall and the part # is 9001-18-18. Thanks for everyones help
motorcarman (03-09-2024)
Chris Steineger
XK120 XK140 XK150
10-23-2018 02:52 PM
