Air suspension oscillation
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
I’m experiencing what appears to be an air suspension oscillation at highway speeds. When traveling at 73mph on a smooth concrete surface highway, the suspension rocks side to side every 2-3 seconds. It is subtle but noticeable. The steering wheel and vehicle direction stays stable. The road is not inducing the oscillation - cars around me are showing no suspension movement. Has anyone had a similar experience?
One other observation. When parked and the suspension height is switched from low to high, the rear end goes up first, followed a second or so later by the front end. Does your car with adjustable air suspension behave similarly?
I haven't seen the problem myself on the highway but I do notice when raising or lowering the car it often does so unevenly but it locks in on the new height pretty quickly. I've had a similar experience with air suspension in the past and even the hydraulic suspension in Citroens was uneven. You might report the highway experience do the dealer and see if he or she can duplicate it. You can find a list of nearly all the problems people have reported in the following link but other than a suspension failure problem I didn't see your issue (but I didn't do an exhaustive search so you might want to try yourself): https://www.i-paceforum.com/forums/j...-problems.474/ Good luck! (Not great moderation on that site as you'll also note a number of offers to sell illicit drugs).
Unless this is you, there is another Pete reporting the same problem on the other forum: https://www.i-paceforum.com/threads/...content=iss100
Mine had this same issue, and for those finding this thread that are also having problems, it ended up being the rear control arms for me. This was similar to a E-Pace problem. My tech's took NINE WEEKS to diagnose and repair this issue, and only after finding the same problem in E-Pace reports.
enderle (09-22-2023)
SebastianV
06-13-2013 08:45 AM
MANIACK
05-30-2012 09:06 AM
