Change Phone number on Jaguar Remote app
If you go into the Jaguar Remote application on your smartphone there are three dots in the lower right on the second screen (swipe left for remote climate). Touch them and you get a menu, select settings. Then go to My Account and you'll see where you can change your phone number. Then go back one level, click on "notification preferences" and make sure the notification you want is turned on. That should do it, good luck!
OK go to https://incontrol.jaguar.com/ go into settings and then change the phone number. I was able to change both numbers in that field so that should work for you. I set my cell phone, for texts, as the primary.
Updating your phone number on the Jaguar Remote app should be a breeze, but it's understandable if you're having trouble finding the process.
Typically, you'd want to head into the settings or account section of the app. Look for options like "Account Info" or "Profile Settings." From there, you should be able to update your contact details, including your phone number.
If you're still hitting roadblocks, maybe try reaching out to Jaguar's customer support. They're usually pretty helpful with this kind of stuff.
Oh, and speaking of phone-related tools, I came across this call intercept feature at https://www.mightycall.com/features/call-intercept/
A post in New Member Area - Intro a MUST forum will give you the opportunity to introduce yourself to the members and get some useful information about using the forum..
https://www.jaguarforums.com/forum/n...eorgia-230937/
enderle (02-20-2024)
