Jaguar 2022 failed Heater
The heat pump system circuit is separate from the heated seat and steering wheel circuits. Did you check the fuses? Also, make sure you are in Auto mode for air conditioning I've found that when it isn't in auto, it behaves strangely (as in I never really figured out how to make it work right when not in "auto"). You could also leak in the system, so it may need to be recharged. I had to do that once every two years with my F-type as it had a slow leak we could never find.
Lawrence Watkins
12-10-2022 08:52 AM
Lawrence Watkins
08-05-2019 07:26 AM
