Shop Manual
Shop Manual
I posted earlier that I ripped off my charging door and broke the latch. So I figured that I'd better get a shop manual along with the parts. Not surprisingly the manual cost more than the parts did. I found the manual at the attached link and got the "DeLux" edition. Not sure what the difference between it and the cheaper manual is but you get a .PDF and it is searchable. It pointed out what needed to be done to pull the fender and replace the broken component. Here is the resource, hope you don't need it. (Be aware that you shouldn't do anything with the electrics without specialized training and safety gear as the high voltages will pretty much ruin your day. But replacing the door is just a matter of a bunch of screws and having someone to help so you don't drop the fender. https://www.factory-manuals.com/expa...anual-842.html
Here is hoping you don't need the thing.
