Burl Dash is Glazed Looking
The story (I cannot verify it) that I have heard is that around 2001 the guy responsible for the wood at Jaguar for decades retired, and they lost the 'formula' for a while. Lots of cars of that era have a finish that has taken on a milky cast. The only solution is to refinish or replace with new or used.
Two refinishers with good reputations are: http://www.britishautowood.com or http://www.maderaconcepts.com/.
You can also buy replacements here: XK8 and XKR Interiors.
Burl Dash Glazed Looking
Oh dear, I was hoping that there was a product you could use on them that would do the trick. It seems I've seen products for such but I didn't know if it would work on the dash or not. I guess it's worth a try if I can find one again. Thank you for all the good information.
If you have a USA 2001 model year Jaguar with "milky" wood, then the only way of fixing it is to remove the finish and redo it. A lot of the XK8/XJ8 models were effected & many wood sets were replace under warranty.
The type of finish used is a Polyester. This coating contains paraffin wax to aid it it's polishing. When the coating is applied, there is a certain "window" between coats, and to cut a long story short, too long and the wax does not rise to the surface of the coating & it can get trapped within the finish. The completed wood can go out the door looking great, but will come back milked-out in 6-12 months or so. I know, I've been through it myself, and around that same period also (Dec 2000). Cheers.
Fletch44
09-28-2015 03:21 PM
