Wood clear coat?
Wood clear coat?
Jerel here looking to refinish all the wood in my 86 xj6, if poop of all of The clearcoat and am ready to Pour a new one on. I was wondering if anybody had experience with the refinishing or re clear coating jag wood. which clearcoat is the most heat resistant and won't yellow and crack as much with age?and what methods I could use to make the woodgrain pop?
Jerel,
I've moved your question from General Tech Help to Interior forum. The topic has been discussed here previously.
https://www.jaguarforums.com/forum/i...wirling-51394/
https://www.jaguarforums.com/forum/i...001-xjr-44331/
Welcome to the j.w.s.,
Somewhere in your area will be a local shop that sells veneer rolls of wood. They will have different types of resin. The best is a product very similar to what Jag uses. It's expensive for a small amount but it's worth it. I've even seen it at Hobby Stores. Can't think of the name but it might be something like Liquid Glass
Matrix Systems clearcoat: $65 (one quart plus hardener and reducer)
