New Jaguar 3.0 supercharged v6 origin?
The new V6 is actually a development from the AJ133 V8, unrelated to the old Duratec...
Jaguar AJ-V6 engine - Wikipedia, the free encyclopedia
The V8's use an OEM Eaton TVS R1900, so the V6 will probably run a smaller version, R1740 or R1320...
The AJ126 V6 is basically an AJ133 V8 engine that has 2 less cylinders and is made on the same production line as the AJ133. It shares a very similar block as the supercharged V8 AJ133, with some unique features such as reduced bore size
The following 2 users liked this post by Cambo:
ronbros (12-22-2014),
Stuart@VelocityAP (05-15-2014)
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The AJ126 V6 block is externally the same dimensions as the AJ133 V8 block, however the casting internally is different.
There are no "blanked off cylinders" it is cast with six cylinder bores. But yes the V6 is physically the same size as the V8.
Jaguar's 3 series fighter to get the F-Type's V6?
Right, done a bit of digging, and it's true the V6 block is the same length as the V8, but it is a different block casting, with only 6 cylinder bores and a smaller bore size than the V8, so it's NOT the V8 block without 2 pistons and rods.
It's still an odd thing to do though, but it means engine bay system installations for both V6 and V8 can be similar according to someone that works at JLR, and the casting costs can be reduced in the engine plant.
It would be interesting to see where the bores are physically located in the block. My conversation with a Jag dealer technician seemed to indicate that they were offset towards the front of the block, which would make sense from a weight distribution point of view.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
just possible that the blocks could be cast in the same basic molds, but internally have six bores!
but also could be machined on some of the same machineries and assembly lines.
would save a lot of development MONEY.
what else would be logical, and the finshed engine would be very robust!
That's basically what I was told, it kept development costs down and also makes it easier to package in the vehicles i.e. same engine mounts, same accessories, etc...
What's interesting there is that it's a 90º V6, as opposed to the old Duratec that's 60º, which probably contributes to the tougher sound. The do sound good for a V6...
speaking about exhaust sounds.
when i was restoring my V12 XJS roadster , i wanted to hear all 12 cylinders, so i custom built an exhaust system where all 12 exit from one large diametr outlet, the sound produced after 4000 rpm is a mesmerizing whine,at 6000 its a whistling scream!
very different from a two or four outlet sound.
many guys say good reports about it, wasnt planned that way but it is what it is.
The use of the V8 style package for the AJ126 engine- well, it's been called 'pragmatic'- using the same casting and not boring out the redundant cylinders and fitting the balance shaft there. I'm going to keep my opinions of this 'pragmatic engineering' to myself ;-)
A 90 deg V6 vs a 60 deg V6- will make more 2nd order in terms of NVH- even with the balancer shaft. The old Mercedes 90 deg V6s did it.
When I was involved in the ill fated X600- one car we benchmarked was the then current SLK which had that 90 deg V6 and the 2nd order was attributed towards it giving a rumbley character-which the clinics favoured. At the time- it was something we were struggling to do on the AJV6 (with it being a 60 deg).
The following 3 users liked this post by Count Iblis:
Actually they are
https://www.reddit.com/r/CarDetails/...tm_name=iossmf
That sounds about right. I didn't mean literally blanked off, like there's a plate bolted to the top or something, hence the parentheses.
magpies
06-27-2019 09:46 AM
tedh
09-17-2008 03:33 PM
2000, 30, duratec, engine, ford, forum, jaguar, kit, motor, review, supercharged, supercharger, superchargers, type, v6
