Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
5.0 Supercharger elec. bypass controll and MAP
Old 11-08-2016, 04:39 AM
AnttiM's Avatar
Default 5.0 Supercharger elec. bypass controll and MAP
Hi
does anybody have types, datasheets, wiring diagrams (also connector pin information) and vacuum diagram for the "new" type 5.0L supercharger available? This supercharger has electrical bypass as seen in the attached photo
background; I was not paying too much attention (as usual ) and got newer than expected version, might be able to figure out something for the control ...
thanks in advance
Antti
Attached Thumbnails 5.0 Supercharger elec. bypass controll and MAP-img-20161108-wa0003.jpeg
Old 11-08-2016, 05:30 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
just lock it shut!!
drive carefully,LOL,LOL
Old 11-08-2016, 05:37 PM
Received 4,458 Likes on 2,427 Posts
Which car are you putting this supercharger in?
Your signature says you have an XJR6 so are you trying to put this TVS on that? It's not clear what you are trying to do...
Old 11-09-2016, 12:31 AM
AnttiM's Avatar
indeed i am planning to put the charger in the x300 xjr. like done in Australia already some years ago.
still in beginning of the planning / part sourcing phase, progress speed depends heavily from the wife-work-house renovation trinity....
for the bypass control : most likely the control is PWM controlled stepper, inputs from ECU. Best case scenario is that I can remove the stepper and convert it to conventional vacuum control or make / find some electrical vacuum measurement sensor that can then be used as input for stepper
or then i need to invest in MS which has boost control function via pwm control already that could be adapted for the bypass, IIRC.
ronbros (11-11-2016)
Old 11-17-2016, 08:35 AM
Tijoe's Avatar
On the 5.0 Superchargers, the first couple of years were vacuum controlled.
I have in my possession one of each variant. The valve bodies appear to be interchangeable being that the housings are the same.
Old 11-18-2016, 10:28 PM
Tijoe's Avatar
FYI: vacuum version image attached
Attached Thumbnails 5.0 Supercharger elec. bypass controll and MAP-vacuum-version.jpg
