Aj v8 timing wedges?
Primary Timing Chain Wedges - 303-533
I'm pretty sure this is what they are. I don't have them. I used one of my plastic trim wedges. Worked very well and they're cheap. Amazon has a set of trim wedges for 11 dollars.
plums (11-10-2012)
If you fit the newer metal body primary tensioners then they will ratchet out and NOT retract without holding the lever. The tools were used with the plastic tensioners that had 'o'rings and check valves.
Once the new primaries are released you won't get much between the tensioner and the guide blade. You might try some feeler gauges or really small wedges.
bob gauff
bob gauff
Wolfy
05-28-2024 08:06 AM
