Cam Timing Tool for AJ27S...
Is a cam timing tool necessary when changing head gasket for a 2002 Supercharged V8?
The car is a RHD Daimler Super V8. First and last cylinder on passenger side (left of car) no compression. Plastic water hose clip broke and car overheated...
Thanks for any help.
Sprint.
Sprint.
I don't have a answer to your question but if it overheated badly and has a plastic impeller waterpump- the chances are that the pump is melted and will need changing too. I've seen this many times. The AJV8 has minimal volume "precision cooling"-which is designed for rapid warm up. This it does well, compared to other engines of similar power- howere the down side is there is less reserve in the cooling system
SprintStar (07-18-2011)
Wolfy
05-28-2024 08:06 AM
philwarner
09-05-2015 10:05 AM
