Can I modify my 1988 Jaguar XJ6 air intake ?
I'm not sure I know what you mean about the system being "sensitive". As long as you maintain an even airflow distribution across the face of the mass air flow (MAF) meter you can make significant changes to the intake system. Having a MAF makes the EMS much less sensitive to engine modifications that change the volumetric efficiency than speed-density systems that rely on measuring manifold pressure in order to infer air flow rate into the engine.
BrentGardner
28
04-26-2024 03:08 AM
