Chevron Techron fuel system cleaner
Has anyone used this and want to share their experience?
This is what it is supposted to do:
Cleans fuel injectors
Cleans intake valves and ports
Cleans combustion chambers
Restores lost power and performance
Lowers emissions
Relieves cold start-up problems
Reduces deposit-related engine knocking and pinging
Cleans sulfur deposits from gas gauge sensors
Protects against fuel system sulfur deposits
Protects gas gauge sensors from malfunctioning
Contains PEA chemistry
![](https://www.jaguarforums.com/forum/attachments/jaguar-engines-transmissions-47/55272-chevron-techron-fuel-system-cleaner-7080568_chv_65740_pri_larg.jpg?dateline=1379605210)
Lowers emissions
Received 2,263 Likes
Techron is the "real deal". I know that Hyundai relabels Techron (kicking up the price, naturally) as their OEM fuel injection cleaner.
Fuel injectors are subject to varnish build up, and I add several bottles of Techron with each oil change. It's cheap. Buy it at Costco for a deep discount.
You can argue that current gasolines carry enough additives to keep your injectors clean; and you maybe correct. On the other hand, gasoline quality does vary from wholesaler to wholesaler; and if you are not correct then eventually you will be looking to remove your injectors for individual cleaning.
Cleaning as you go with Techron will not necessarily forever eliminate the need to remove and clean injectors, but it probably will extend the useful life of injectors by a material amount.
It does not clean the intake valves on the newer Jag engines due the the direct injection system. The fuel no longer flows over the intake valves, but is injected directly into the cylinder. The problem with the new injection setup is carbon builds up on the intake valves and slowly reduces performance and mileage. Sometimes requires the cylinder heads to be removed to clean the intake valves !![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
Have you seen this first handed on a Jaguar engine? The professional techs that post here say 'no such thing'.
My tech (actually the Jaguar service manager) said he has only seen a couple Jags that had carbon build up and he sees a lot of Jags! Looks like Jaguar has a better designed engine than most. After seeing Audis with the problem, I was a little concerned! I'm not saying Techron doesn't help our engines (I use Chevron gas), just informing fellow Jag owners what Techron doesn't clean the intake valves in the new engines.
OkieTim
09-08-2015 04:48 PM
deanh
09-06-2015 08:20 PM
