ECU Tuning Group | Jaguar 4.2 Supercharged ECU Upgrade
By reprogramming the ECU, not only were we able to increase power for the Jaguar 4.2 Supercharged engines, we were also able to remove the speed limiter, hesitation/flat spots, and raise the RPM all while improving fuel economy by 10-15%.
Total gains achieved by reprogramming only the ECU on the XJR/XKR/XF/S-Type R 4.2L Supercharged Jaguars is 25hp & 24lbs tq. By complementing the ECU tune with a pulley, gains are 55hp & 65+lbs tq.
For owners who are not accessible to any of our dealers, you are in luck. We are offering a new package where you will be able to reprogram your vehicle through the OBD II port in the comfort of your own home. The process is simple, safe, and easy. Contact us directly for more information.
Please inquire about any Jaguar model.
Contact the sales department for any questions or concerns.
Please obey all traffic laws. ECU Tuning Group does no encourage speeding.
The following 8 users liked this post by sales@ECU Tuning Group:
1 of 19 (05-04-2016),
djdoug0341 (12-20-2014),
gjjaguar (12-10-2013),
m.w.l. (02-10-2016),
rocknrollteddy (07-20-2015),
and 3 others liked this post.
55 hp is 55 hp. I would like more, but I'll take what I can get. My question is, generally speaking, if I was to add a Quicksilver exhaust mod in addition to an ECU tune and pulley upgrade, is there any additional hp gained over the 55hp? Also, what type of intercooler mod would you recommend?
The ecu tune is completely undetectable to factory diagnostics. The 'tuner' we provide are for customers who are not accessible to any of our dealers. Even then, once they receive the tool and reprogram their car, they must return the reprogramming tool back to us. Being that you are in a different case, after having the vehicle tuned and you decide to remove it years later, just contact your dealer and they will be able to remove the tune 'no questions asked'.
I'm very interested in your tune. I have a 2004 s type r with a overdriven eaton blower, alcohol injection and magnaflow exhaust. Is your tune a 1 size fits all thing or would I be able to request a few minor changes to get it to work better with my modified car?
You mention dealers. I'm located in so cal. Do you have any dealers near by? Have you worked on any forum members cars yet?
Finally, how much are the tunes? Feel free to pm me if you'd like to discuss via pm. My car would be an interesting canidate to see what's possible hp wise with the common mods to the car.
Pricing on all tunes can be viewed on our website here.
As for other forum member's cars, yes we have worked on a numerous amount.
Wow, thats bummer because those are very common mods for these cars. The re-geared blower increases boost from 13 psi to 16.5 and alcohol injection assists in inter cooling and with octane. The re-gear is similar to using the euro toys lower pulley or using a 3lb pulley from the other various manufacturers that advertise here.
Does your tune add power by leaning out the air fuel ratio or by adding timing? Either way, alcohol injection would not be harmful. Itd be leaving power on the table but it wouldn't be harmful... I'm surprised you haven't run into this combo before.
When I was researching cars prior to getting my XKR, I noticed that there were several install-it-yourself piggyback ecu boards for BMW's.
While I would think that developing some economical tuning software that could be used with a laptop would not be rocket science, sadly, there seems to be nothing like that for our Jaguars
![Icon Violin](https://www.jaguarforums.com/forum/images/smilies/icon_violin.gif)
Doug
The GF chip looks like snake oil to me. Given that they advertise chips for virtually every vehicle in existence, I bet it is one of those generic chips that try to fool the ecu in some generic way and not really custom tuned to the particular vehicle.
What I am talking about is some programmer or software that is more specific to a vehicle where it permits you to make changes to such things as timing and fuel curves.
Doug
Doug
I would NOT use 1 of those $69 chips. Some just use a resistor in te MAF that tells the ECU its very cold out and advances the timing to make more power. Very bad things will happen in the hot summer months as you ca nimagine.
A complete re-map like ECU Tuning Group does is the way to go.
I think their price is a tad high for me but I still think I may dive in just cause I am a power junky!
sales@ECU Tuning Group (03-14-2012)
I did see something that looked a bit more promising by Volo Performance where you added a board/chip to the obd port and downloaded a program to the ECU (apparently this is reversible) but googling turns up comments on both sides of the fence (either the product is junk or it is the best thing since sliced bread). Something like LT-Edit where you actually could see what you are doing on a laptop would be preferable.
Doug
Doug
