Kenny Bell Upgrade among other Things
500 at the hub for a 3"pulley is in the ballpark you can expect. Here is another hub dyno result for a 4.2 XJR, with a DBX85/82mm TB, but bigger 4.2 lower pulley (assuming you have still the 4.0 one?)
https://www.jaguarforums.com/forum/p...6/#post1213836
This upgrade has been a long and expensive mission... I have had fitted a new ECU which can cope with the additional power, the MAP on the original one was not capable of managing the fuel air ....etc
A long update is coming but have to wait till i take a holiday to get the time to do it..
The MAF was fitted in the bumper, I think the same place AVOS fitted his. Difficult to get to if you want to mod unless you fit a extended USB port lead.
not sure if this helps you.
I've had the same troubles - Abaco appear to have gone broke - No problem to me - I use a MAP and leave the (Abaco Junk) MAF wired to the Jag computer - (same with original injector and coil wiring, shorted out with resistors) -
My ECU is Infinity - The engineer has emailed me a week ago, saying they are only a few months away from releasing a full kit = THROW THE JAG ECU AWAY, which will run all of the Original Jag ECU operations plus be fully programmable
Received 1,236 Likes
trosty
26
12-18-2022 06:40 PM
abonano
25
09-25-2015 10:43 AM
