Upgrade water pump xjr? Aluminum Thermostat housing?
When I go in to change the thermostat to a lower temp, should I also change / upgrade the water pump?
Is this the upgraded water pump you guys would recommend? Jaguar 4.0L V-8 Water Pump & Gasket 97-03
2002 JAGUAR XKR Parts - Direct JPLV Porsche Parts.com
Have a look here, there is some more info to be had, including the thermostats available:
https://www.jaguarforums.com/forum/s...ficient-73789/
Newby (06-03-2012)
