Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
water - alcohol injection
Old 05-31-2010, 12:17 PM
flsupraguy's Avatar
G
Originally Posted by super_jag
I am going to receive an AIS trunk mount Stage 1 system in the mail soon let you guys know how it turns out.
http://www.alcoholinjectionsystems.c...duct_info.html
How did it turn out?
  #42
Old 06-01-2010, 11:54 AM
super_jag's Avatar
well pretty easy install, and the led inside lets me know when it sprays, I will have to update on dyno numbers.
  #43
Old 06-19-2010, 04:06 PM
Riski's Avatar
any dyno numbers yet.....what about the butt dyno?
  #44
Old 08-10-2010, 07:11 PM
qwiketz's Avatar
what nozzle are you guys running on your alky kits? I was told a 625 would work great on mine. I'll install in probably about 2 weeks.
  #45
Old 08-13-2010, 10:28 AM
stypernut's Avatar
Hi
Where are you planning to place the nozzle? pre or post SC
  #46
Old 10-30-2010, 02:28 PM
qwiketz's Avatar
I'm going to place it pre supercharger. To run it post supercharger you'd need a solonoid to keep the fluid from being sucked out of the line when in vacuum. I'm actually doing part of the install today after I get my butt up....
Can anyone give me a idea of what the maf wire that I'm supposed to hook this thing upto looks like? Or, maybe can someone tell me where the map sensor is located on the car to save me some time hunting around? I haven't looked yet.
  #47
Old 10-31-2010, 01:26 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
The MAP sensor is at the back of the intake elbow, maybe you can see it with the TB off. The vacuum is about the same pre or post the SC, unless you mean pre-TB of course?
  #48
Old 11-03-2010, 06:19 PM
qwiketz's Avatar
correct, I was thinking pre/post TB.
  #49
Old 11-03-2010, 06:20 PM
qwiketz's Avatar
where did you end up mounting the led and how did you route it? Did you use a vaccuum/boost based controller or one that reads the MAP signals? Finally what size nozzle are you running and when are you having it flip on? Is it a progressive kit?
  #50
Old 05-15-2011, 12:23 PM
Michael Star's Avatar
This thread needs more pics/info
  #51
Old 04-26-2012, 08:03 PM
Jeff in Tucson's Avatar
Default Updates?
I've been thinking about a progressive water-alky injection kit, too. It's around 105 degrees Fahrenheit all summer long here.
  #52
Old 04-27-2012, 11:48 AM
qwiketz's Avatar
My setup wasn't worth anything on the dunno but it absolutely has to kill any potential knock due to the octane.
Panthro (04-27-2012)
mikiep
12-20-2019 07:37 PM
Spazzzzzzzzzy
10-04-2015 05:37 PM
millertic
09-30-2015 08:11 PM
XKE73EIconverter
09-26-2015 10:21 AM
Quick Reply: water - alcohol injection
