Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Adding Quotes to posts
Old 07-03-2014 | 05:11 AM
o1xjr's Avatar
Default Adding Quotes to posts
I have been adding quotes by clicking on the wrap quote tags button then pasting the text I want between them. But it doesn't show the line
"originally posted by ,member name" doesn't show up.
Originally Posted by JagCad View Post
Is there way to do this I am missing,or am I adding the quote wrong?
Thanks in advance.
Old 07-03-2014 | 05:24 AM
Thanks in advance.
You want to click on the black "Quote" button at the bottom right of the post you want to quote before you start your reply.
This one!
o1xjr (07-03-2014)
Old 07-03-2014 | 05:54 AM
o1xjr's Avatar
[QUOTE=Norri;1007609]You want to click on the black "Quote" button at the bottom right of the post you want to quote before you start your reply./QUOTE]
Thanks Norri, never saw that button there.
Old 07-03-2014 | 05:55 AM
o1xjr's Avatar
This one!
Maybe this time?
Edit, Got it now by look of it.
So now ,how does the multi quote button work?
Old 07-03-2014 | 06:47 AM
If you want to quote more than one person click multi quote first then the regular quote and it should end up like this:
This one!
Maybe this time?
The following 2 users liked this post by Norri:
LnrB (08-13-2014), o1xjr (07-03-2014)
Old 07-03-2014 | 07:30 AM
o1xjr's Avatar
Thumbs up
Maybe this time?
Thanks.
Old 07-03-2014 | 07:45 AM
Thanks in advance.
This one!
Thanks.
And of course you can hit the multi quote button more than once!!
If you want to quote from another thread, just hit the quote button then cut and paste to the thread where you want it.
Originally Posted by GGG
Emecik - Turkey
The following 3 users liked this post by Norri:
JimC64 (07-03-2014), LnrB (08-13-2014), o1xjr (07-04-2014)
Old 08-04-2014 | 08:16 PM
Gippsland's Avatar
I use that 'quote' button and still get all the bits.
Old 08-04-2014 | 08:18 PM
Gippsland's Avatar
Except that time?
Old 08-04-2014 | 08:41 PM
So you're not using the multiquote button?
If I hit the regular quote button it goes straight to a reply box with no chance for a second one.
Old 08-05-2014 | 03:37 AM
o1xjr's Avatar
Hi Neil,I had trouble when trying to quote previous posts. Read the link below,it was a huge help.
https://www.jaguarforums.com/forum/j...-posts-121167/
Clarke
Hi Neil, it took a while but a bit of trial and error after Norri's instructions got it over the line.
I just tried it out on an old thread and kept hitting the preview post button until I got it right,but never actually hit the submit reply button. You can practise that way without posting anything.
Even for a computer illiterate like me I got there eventually.
Old 08-05-2014 | 04:45 AM
Gippsland's Avatar
I've always used the 'quote button' but often back space out anything not relevant.
