Any talk of an iPad app interface?
I know the m.jaguarforums.com site works well for my phone screen, but my tablet seems to ignore it and reverts to the main website. I find the text is too small and I have trouble hitting the right buttons. Oh the horror!
I'm also on the club touareg forum, which as far as the layout goes looks like they run on the same forum engine as this one, but they have a iPad app that I use when surfing from my couch. I can still use their browser interface if I need more functionality.
But most importantly, the icon for Club Touareg looks better than the icon for the Jaguarforums web link (see attachment). And we can't have that.
Just throwing out an idea if somebody is bored, not suggesting anyone donate hundreds of hours of unpaid coding time unless its a labor of love.
I may have answered one part of my question myself. When I touched the "default style" button on my iphone it went to the full web page, and then, like with my ipad, it wouldn't ever go back to the mobile-specific interface again. When I reset my cookies and deleted my history it started loading the mobile interface again. I'll try this with my ipad, and maybe it will help.
Ah, ha. I am probably breaking several rules by continuing to reply to myself, however...
I have found a handful of threads with similar concerns
here, here, and here (and I'm sure a few others).
I am surprised to find no FAQ on this subject except what seems to be vBulletin canned text under miscellaneous options:
I finally found the little drop-box selection at the far bottom-left corner of the website that looks like this:
The only two options that seem to work are the desktop version, called "Jaguar37", and the phone/tablet option that is called "Lightweight." Don't use the option called "Mobile theme" because it is quite buggy. Or if you do, and you get stuck as I was, you may need to clear your browser's 'cookies' to reset.
Admins, shouldn't these unstable options just be removed from the choices available?
'Forum Style' - only available if there is more than one style (or 'skin') available and the administrator has enabled this selection
Jay, I have no idea about tablet options because I don't use one.
However, I permanently run the 'Default Style' because it shaves the forum down to the bare bones for VB.
No banners, no themes, and no 'other stuff', no icons, etc.
I have a slow connection speed, and the removal of 'things' I don't need to load not only speeds up the forum but also frees up useable space on my laptop.
Give it a go.
You need to log in and make the change from your user CP.
It will only appear when you are logged in and will revert to '37' when you are logged out.
But if you have made the change to Default then as soon as you login the forum will load as basic VB style.
You might not like the look, but it certainly makes an improvement for my forum browsing experience.
If you get stuck, sing out.
Give it a go.
Muddydog (02-04-2013)
Well look at that. Just when I thought I had tried everything! I'll try it out on the tablet later, but at first glance it looks like it might be easier to use. Thanks for the tip.
*edit - it makes a huge difference. Thanks.
Ok, trying out some options I did:
User cp
Mobile
Now whenever I log in, I get redirected to http:///forum/ which, of course is nothing.
No change after removing cookies, changing browsers etc.
When on my phone, no trouble. Phone is how I post this support message.
So, the full user CP is not available on the phone, so I can't change my preference away from Mobile preference. When on Computer, get bogus redirect after login.
Moderators help? Can reset my preferences?
-mag
User cp
Mobile
-mag
Ah, I see. You made the change from your User CP, under "Options", rather than from the bar at the base of your screen, as I was doing above. When you do it your way it resets your preferences on the server side, rather than within a cookie on your browser's side. When you reset it from the bar at the bottom of the screen, it sets that preference only for that browser/device and can be reset by clearing the cookies.
Do this. While on your mobile device, and logged in, enter the following address in the browser bar:
If you can successfully navigate to this page on your phone, then you can reset your style to Jaguar37 and you are in business.
You may still have to clear your cookies on the browser as well after that.
Or a mod could just reset it for you.
Code:
https://www.jaguarforums.com/forum/profile.php?do=editoptions
The following 2 users liked this post by Muddydog:
magmedia (02-05-2013),
Translator (02-05-2013)
Code:
-mag
Received 9,007 Likes
Muddydog (02-05-2013)
