Empty Garages and Guest Garages
Hey folks, we seem to have a lot of empty garages around the place, why not add at least one picture of your pride and joy.
Also of note;
Hi there, sorry for the earlier short reply it was around 3am, we have looked into this issue and discovered that there appears to be no deliberate hack.
When a member becomes inactive, eventually they are reduced to Guest member status, this then allows them to return to active status at a future time, if they so request.
A member showing as a Guest can not make any posts to the forum.
However, if you or any member, me for example, finds themselves within an old 'Guest' thread then your or my garage will display.
This is not something to worry about as the visible garage is linked to the member viewing the thread and not the Guest member.
So if you click on Guest threads where a garage is present, you will see your own garage, because the Guest garage pictures have been effectively removed from viewing.
In fact, if you click on an empty garage you will be directed to a page showing your own garage at the top of the list.
Guest threads tend to be very old and do not often reappear in the active sections of the forum, however with some of the recent reorganization they may have had a bump in some of the New older Jaguar sections.
Care should be taken to check the date of a thread.
Only the owner of the garage or a member of the forum staff can edit the contents.
Hope that this clears things up a little,
Also of note;
Received 9,007 Likes
