Only one thumbnailed image per post?
Just hit a curiosity... Reference post HERE
To avoid filling your storage, I have a hosted thumbnail image and select "Insert Image"
Then I select the thumb and link to the larger version..
Like so:
A second image done the same way does not show up in the post
Yet I see them both in my editing, and post preview... but they are not there when I submit the post...
If I log out, they are there... If I log in they are gone...
Am I making mistakes?
Thanks for your guidance
Vince
(Sure enough, the links here work fine...grrrrr)
Like so:
![](http://farm9.staticflickr.com/8313/8028714445_9f16346447_t.jpg)
![](http://farm9.staticflickr.com/8322/8018237142_665f8df72d_t.jpg)
Vince
Hey, I edited the images in your topic please don't mind . I am gonna show you how to show the images I think http:// was the culprit
![](https://www.jaguarforums.com/forum/attachments/jaguar-forums-advice-feedback-suggestion-center-18/24059d1348739213-only-one-thumbnailed-image-per-post-image-inserting-jpg)
When you insert http link you should delete the http:// in the Image Insert pop up that is the blue highligted one . This is what I do because if you don't this then images don't show up
Another thing you should use the image link that you see when you click on . In your case ,your original post where it begins with A second image .....
I click on the image and see it original size .Then I left click on the link ,not the right click on the image , this is important . Use the 1st one when you wanna insert an image
2nd image is what I am talking about
Thanks,
Looks like I need to play a bit with it....
I dislike the larger image as seen in post number 2 here... A long thread could get cumbersome loading images of that size... the thumbnail is a much cleaner and faster load.
test - thumb only via insert image
![](http://farm7.staticflickr.com/6048/6868888644_652ee115ce_t.jpg)
test - thumb with embedded hyperlink
test - Full Image via Insert Image
![](http://farm7.staticflickr.com/6048/6868888644_09f8a1982a_o.jpg)
Thanks, guess all works fine but I didn't see any change I made... maybe it was the beer or two I had while trying...
Thanks for your patience....
Vince
Vince
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
FS[Canada]: Vancouver BC FType lease takeover
nd143
09-03-2015 04:42 PM
