XF Message Center
Welcome to the forums alimacno,
As it says at the top ...THIS SECTION IS NOT FOR TECHNICAL QUESTIONS. It is for comments and questions about the forums.
However, as you have landed here, I'll reply to the question. The message you have seen is the TPMS (Tyre Pressure Monitoring System) confirming pressures are set for normal load. The recommended increased pressures for carrying heavy loads will be shown in the Owner's Handbook. Unless you are setting off for an extended holiday with full luggage, you need not be concerned.
FS[MidWest]: 1997 XJ6 zero rust! $2800
jgjeeper
04-25-2015 08:41 PM
RSR Racing
05-29-2013 03:32 PM
