1998 xj8 sunroof problem
Old 06-09-2011, 12:24 AM
Fyrplg's Avatar
Default 1998 xj8 sunroof problem
The sunroof will not lock down at the rear.
When I purchased it the rear piece of upholstery was in the trunk. Installed and top not latching down. It pops up when closing doors.
Is there away to make this lock down? the plastic rails seem all messed up.
If I could just decommission it it would be fine with me as I had a 1996 xj6 that sunroof would not operate properly but did latch down.
keeping it closed will work for me at this time.
Old 06-09-2011, 08:04 AM
jimlombardi's Avatar
Received 1,623 Likes on 874 Posts
Hi
I found this posting by forum member motorcarman that has TSBs on the sunroof (sliding roof) with repair instructions and illustrations:
https://www.jaguarforums.com/forum/j...sunroof-55344/
TSB 13-39-sliding-roof & TSB 501-26-sliding-roof have repair info that can be done without PDU (Jaguar Scan Tool)
https://www.jaguarforums.com/forum/a...81-xjr-sunroof-
https://www.jaguarforums.com/forum/a...16-xjr-sunroof-
Jim Lombardi
Old 06-11-2011, 12:17 AM
SuperSport's Avatar
Originally Posted by jimlombardi
Hi
Jim Lombardi
Jim, you are FILLED with usefull information and helpful research. Thank you for all your input around here...
SteveSheldon
UK & Eire
505
07-14-2016 04:48 AM
Rlover
03-30-2016 10:04 PM
arnoldmilk
09-03-2015 07:42 PM
laserguy
09-03-2015 02:02 PM
King Charles
09-03-2015 12:40 AM
Quick Reply: 1998 xj8 sunroof problem
