JTIS for my 2001 XJ8 VDP
Can't contact (Christo) on Christo's JTIS Download Site.
Trying to download and access JTIS on mediafire.com (a third party cloud) to no avail.
Download issues out the wazoo. Anyone with the solution how to get there please help.
http://www.mediafire.com/?sharekey=3...e4b9ac475cdcd3
http://www.mediafire.com/?sharekey=3...d9941c0a3e731b
Thanks,
Thomas
Thanks,
Thomas
I believe that I have the downloads. Send me a PM with your off-forum address and I will send to you. They come in two parts that have to be burned to a cd. JTIS is set up to only be accessed from the cd drive. I never found a way around it. Also took some time to get the Vista OS to work and have no idea how the new MS 7 OS will handle it but that would also be true with a $10 cd off ebay.
Hi test point
How did you get the JTIS installed on your PC with the Vista operating system on it? I sent SirJag a copy of the CD and he had a problem when he tried to run setup.exe in the DA035/Disk1 folder with Vista. Here is what he said in his email to me: nothing happened at the installation step… sort of just stopped doing what it was doing.
I know the copy of the CD is ok because I did a test install on my wife's PC that has XP home edition .
Please enlight us on the steps you had to take to get it installed on your Pc that has Vista.
Jim Lombardi
Jim Lombardi
Hi test point
Jim Lombardi
Jim Lombardi
Thought I saw a cd icon.
The dl was 470MB.
tia
I found xp_fix.exe on another later JTIS CD I have
Hi SirJag & ant17
I found another JTIS CD that I bought about 6 months. I had misplaced and I just found it this afternoon. It has an xp_fix.exe file and I copied to my JTIS folder on one of my HDs. Here is the zipped xp_fix.exe file (I had to zip this file because the exe file format is not allowed as an attachment):
xp_fix.zip
Try running it, reboot PC and then do the install again.
I found these instruction on another website:
"TROUBLESHOOTING:
If problem should occur, cease JTIS installation, then install the "xp_fix.EXE" program that is included on The JTIS CD. Then repeat installation of the JTIS program."
Jim Lombardi
xp_fix.zip
"TROUBLESHOOTING:
Jim Lombardi
Hi ant17
Is your vista a 32 bit or 64 bit operating system?
I found this article on the UK Jaguar forum.
"JTIS most definately will run on windows 7. I have version 1.3 running on my windows 7 desktop and laptop with no problems at all.
You need to run the installation file as administrator and it will work perfectly.
ie right click on the setup.exe file and select run as administrator.
All previous installs will need to be completely removed first. Hope this helps"
Here is the webpage link:
Jaguar Forum.co.uk • View topic - JTIS ????
Hey - give it a try - this might be the easy solution to getting it running in windows 7!
Jim Lombardi
Jim Lombardi
Hi ant17
I also found this article in the CNET forum on CNET.com:
Post 11 of 15
Re: Yur System32 problems
by Tufenuf - April 10, 2005 8:02 AM PDT
In Reply to: Re Yur System32 problems by ecanuck
ecanuck, If you're having this problem "16 bit windows subsystem" you could go to the link below and download "XP_Fix.EXE".
"This installaton program will reinstall the missing or corrupt Windows XP system files command.com, autoexec.nt and config.nt. The absence or corruption of one or more of these files causes a "16 Bit Subsystem" error.
We recommend that you download this file and save it to your desktop or to another location where you can find it. Double click on the file to run it once it's downloaded. If problem reoccurs in the future, simply re-run this program".
Here is the webpage link to CNET forum posting (see post #11):
http://forums.cnet.com/7723-6142_102-97312.html
Jim Lombardi
Post 11 of 15
Jim Lombardi
Hi ant17
Jim Lombardi
Jim Lombardi
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
