Need step by step guide to changing coolant on 98 VDP
Hello all, need a step by step guide to changing the coolant on my 98 VDP. Yesterday, the thin plastic tube on top of the engine broke and a lot of the coolant was lost. Just got the car 2 months ago so not too familiar with the car's inner workings. Any help would be much appreciated. Thanks.
Coolant change extract from JTIS
Here are the instructions and illustrations from the Jaguar JTIS CD.
I created this PDF file from the extract:
1998 Jaguar Changing Coolant .pdf
Hope it works for you
Jim Lombardi
Jim Lombardi
Last edited by jimlombardi; 01-17-2013 at 08:49 PM. Reason: had to change the attachment location
thank you, jim
I will give it a try, jim. I took a second look today and realized that the damaged hose was just part of the problem. Some kind of animal (rodent???) got into the engine compartment and chewed up some wires to the passenger side headlight and most likely did the damage to the coolant reservior hose also. I should have figured it out when I saw some engine compartment insulation material all scratched up and scattered around. Those damn rodents. Anybody with advice on how to keep animals from crawling into your engine compartment and causing havoc??? I have only heard of such problems from others and I guess I am now one to experience it too!
KarimPA
09-03-2015 07:32 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
