Is it possible to turn OFF the parking sensors...
Old 04-02-2011, 12:50 PM
SirJag's Avatar
Default Is it possible to turn OFF the parking sensors...
... or is the function on all the time?
I can't seem to find anything specifically about that.
Thanks, gentlemen...
SirJag
Old 04-02-2011, 01:53 PM
Sean B's Avatar
Received 1,356 Likes on 1,067 Posts
I'm guessing here, but mine are disconnected at the moment as it's being built up after paint....mine does a long beep, like to backup limit is reached, so disconnecting the sensors won't help. I'd suggest unplugging the speaker, but it's a bit of a pain to get to. It's under the rear parcel shelf, again on mine, maybe it's somewhere easier for you to get to. Do you want it off? hope this helps!
SirJag (04-02-2011)
Old 04-02-2011, 02:11 PM
SirJag's Avatar
Hi Sean!
I'm getting that long beep when I first put it in reverse. I've read that this is a fault indicator, but since I'm not sure if this function is always working (the parking sensor function), I don't know if there's anything more to do to make it work correctly except put the car in reverse.
Thank you!
SirJag
Old 04-02-2011, 03:05 PM
Sean B's Avatar
if it's a faulty sensor, which seems likely, you can check by listening to each of the four in the rear bumper. If you hear one clicking away, you'll need to replace it I think. What's the search function brought up on faulty parking sensors?
SirJag (04-02-2011)
Old 04-02-2011, 05:17 PM
jimlombardi's Avatar
Received 1,621 Likes on 874 Posts
Default Here is another backup sensor thread on the forum
Hi
I found this tread on the backup sensors dated 8/27/2010.
Here is the link:
https://www.jaguarforums.com/forum/j...sensors-29441/
You might want to connect member Stu 1986. He has some hands-on knowledge. He is located in the England.
Jim Lombardi
SirJag (04-02-2011)
Old 04-02-2011, 06:57 PM
Stu 1986's Avatar
It is true-I am in the UK and have hands on knowledge! (Sean B does too)
Basically if you want the sensors to not work at all unplug the sensors from the module in the trunk fuse box and from here I think you can also disconnect the speaker. Look for a solid blue & a solid red wire-these go to the speaker. (According to the wiring diagram) Either cut them or disconnect them that should stop your speaker from sounding.
Hope this helps
Stu.
SirJag (04-02-2011)
Old 04-02-2011, 08:21 PM
Hi SirJag
Here is a PDF with Diagram and parts list of the Parking Aid component and their locations (also the colors of the wires):
xj8 parking aid info.pdf
Jim Lombardi
SirJag (04-02-2011)
Old 04-02-2011, 08:50 PM
SirJag's Avatar
Hi SirJag
Attachment 9197
Jim Lombardi
Thanks Uncle Jag Jim!!! ;-)
I want to get them working... so I'll test it and check that wiring too. Also going to shut the PC down tonight to install the software.
SirJag
Old 04-03-2011, 05:17 AM
Stu 1986's Avatar
I thought you wanted to turn them off? Either way by following the wiring tips we've given you, it should be easy to trace your problem. It is more than likely a loose wire or faulty sensor.
You will want to jack the back of the car up, or if you don't have a jack & stands reverse the car up a steep slope and stop just before the back wheels go over the crest. This will leave your overhang accessible. You may laugh at my suggestion but I've had to do this a couple of times in the past to access the underside of coaches when I've had to do a get me home fix! Gladly I won't have to do that now I've switched to a new (better) company!
Old 02-01-2015, 07:23 PM
Novella's Avatar
Default 2006XJ8 Back Up Sensor Problem
The sensor sounds when backing up, even when nothing is behind me. I don't know where the sensor is located, if its bad, or a connection is bad. What is the most likely cause.
Old 02-02-2015, 08:56 AM
Jhartz's Avatar
I would guess one of the sensors is covered up (dirt, sticker). Happens to me whenever I am backing with the bike rack installed.
99xk8guy
05-28-2024 09:36 PM
Adam Lueb
09-28-2015 02:54 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
DuhCar
09-11-2015 10:58 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Is it possible to turn OFF the parking sensors...
