Timing chain bottom sprokets
Old 05-13-2011, 03:13 PM
semyr19's Avatar
Default Timing chain bottom sprokets
I am changing the timing chains on my 2000 XJR. Everything is going better then I had expected. I did just have a question come up that I hope someone can help. When I removed the first chain going to the crank, I slid off the sprocket. I left the back one on. When I reinstalled the front sprocket, I noticed that the teeth on the sprockes where 1/2 tooth off from each other. I made sure I installed it the same way I had removed it (I think). If I flip it over the teeth line up. I also notice to dots on the sprockets. Do thay have any meaning?
Thanks for any help.
Scott
Old 05-14-2011, 04:41 AM
pd_regan's Avatar
Scott, your doing right, they need to be a 1/2 tooth out to be correct. Checkout the pdf 3 page 2
Pete
File Type: pdf
File Type: pdf
The following 2 users liked this post by pd_regan:
popeye68 (05-14-2011), test point (06-15-2011)
Old 05-15-2011, 08:54 AM
semyr19's Avatar
Thanks.
Wolfy
05-28-2024 08:06 AM
RoyLittle0
05-25-2023 02:38 AM
SD96XJ6L
01-12-2022 04:30 AM
Bowman
09-15-2015 06:54 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: Timing chain bottom sprokets
