XJ8 water pump, drain & Bleed - R&I JTIS21
Time for some Engine Cooling - Water pump R&I from JTIS21 CD.
Here is PDF file that covers the Coolant Drain & Bleed Instructions and Illustrations:
1998 XJ8 Coolant drain refill R&I.pdf
This PDF covers the Water Pump Removal & Installation:
1998 XJ8 Water Pump R&I.pdf
Also here is a link to Jpeg file covers the Accessory Drive Belt Removal & Installation:
https://www.jaguarforums.com/forum/a...503-water-pump-
Jim Lombardi
Jim Lombardi
The following 4 users liked this post by jimlombardi:
Attachment 10951
Attachment 10895
Jim Lombardi
Attachment 10951
Attachment 10895
Jim Lombardi
The following 2 users liked this post by Viapa:
3timejag (01-10-2016),
terrylcook (02-11-2019)
Hi Viapa
I think you are asking for Jaguar Shop Repair Manual. One of the forum members (iguide) has created PDF download files from his subscription on the TOPIx website. He is giving forum members a special price of $25 (for download of the PDF files).
Here is the link to the tread that has all the information:
https://www.jaguarforums.com/forum/j...-manual-54184/
Your other option is to download the JTIS21 software from the forum's large file storage on Mediafire. Then follow the instruction found there on install and use of the software.
https://www.jaguarforums.com/forum/j...uctions-54640/
Look at Post #3 to see special instructional information, then Post #1 for the free download information and link to download JTIS21 software archived files.
I think buying the PDF download files that seems to contain the same information (as far as XJ8/XJR models) that is in JTIS21 at a price of $25 is a good deal.
Never mind the dubious legality of subscribing to Topix, downloading the info, and then selling it as if it is your own. Actually I take it back, it's not dubious at all. It's definitely not legal.
For $44.95 you could have your own, completely legitimate, subscription to Alldata DIY for 5 years, with updates, etc.
Hi Troy
I created the following 3 pdf files for X308 XJR water pump r&i from the JTIS software:
Here are the weblinks:
water pump r&i
https://www.dropbox.com/s/3o2qb5874n...r%26i.pdf?dl=0
Cooling system drain/bleed/refill r&i
https://www.dropbox.com/s/sud7xqjkn2...bleed.pdf?dl=0
Supercharger belt r&i
https://www.dropbox.com/s/sqppum35uf...r%26i.pdf?dl=0
water pump r&i
The following 3 users liked this post by jimlombardi:
Guy-Pierre Boucher
09-16-2015 05:55 PM
1998, bleed, cooling, diagram, directions, installation, jag, jaguar, pump, pumpjaguar, removal, system, water, weaterpump, x308, xj8
