XJR sunroof
Old 05-27-2011, 03:39 PM
itstrickiedickie's Avatar
Default XJR sunroof
I have a lovely XJR only thing is I can't get the sun roof to open and shut properly. When I push the button to open it it opens right back (past the normal open position). The consequence is drumming from the air passing the roof. When I try to close the sunroof the motor takes it past the closed position, raises the rear if the roof then closes down and opens to the far rearward position.
The motor operates OK and the wiring appears to be sound.
Does anyone know about the problem and even better have a solution?
Old 05-27-2011, 11:25 PM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
There is a calibration procedure described in a TSB in the form of a .pdf posted by motorcarman one of the sunroof threads. The search function should bring the threads up.
Old 05-28-2011, 08:21 AM
Received 8,134 Likes on 4,908 Posts
Everything you ever wanted to know about X300/X308 sliding roofs.
bob gauff
The following 2 users liked this post by motorcarman:
Catenaccio (01-05-2014), jimlombardi (05-28-2011)
Old 01-03-2014, 01:12 PM
TheHilds's Avatar
Default Update
After reading the TSB's on the link that Scott posted I found that the sunroof gears just weren't engaged. That little quarter turn after manually opening the roof solved the problem. Good to be able to open it and enjoy. Thanks again.
MidwestJag (01-03-2014)
vwbusbits
10-13-2015 03:43 AM
xjrjag
10-12-2015 03:16 PM
Tipptone
UK & Eire
10-01-2015 10:50 AM
vwbusbits
10-01-2015 01:17 AM
moff1959
09-26-2015 05:35 PM
Quick Reply: XJR sunroof
