04' XJ8 Rear Window Trim Failure
After the unseasonable snow last week in Dallas, it seems a piece of my rear window trim has separated from the body. The trim piece around the upper portion of the driver side rear door has come loose. I'm not sure if the cold simply made the glue separate or if this is a more common structural failure. Thoughts on a fix and or suitable source for replacement?
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/7346d1295198030-04-xj8-rear-window-trim-failure-imag0089.jpg)
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/7347d1295198078-04-xj8-rear-window-trim-failure-imag0090.jpg)
It would be great if someone had some assembly/disassembly pictures
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
So I've found the piece that attaches to the actual window... but not the chrome trim piece that runs the length of the window frame.
https://www.partswebsite.com/jaguarp...imagecallout=1
Doesn't seem to be! I'll send it to a moderator for posting.
99xk8guy
06-05-2023 06:28 AM
