anyone know the subwoofer specs for the alpine car?
Old 05-23-2011, 03:03 PM
Jsedita74's Avatar
Default anyone know the subwoofer specs for the alpine car?
im looking to replace them w more powerful ones but keep the system stock as possible...
Old 05-23-2011, 03:07 PM
Jsedita74's Avatar
i meant alpine system sorry
Old 05-23-2011, 03:23 PM
Greenhornet's Avatar
Default Sub
It's 6.5 subs, one or two. I switched them out and put in a Kicker 6.5 inch Sub, it fit fine, no problems.
Old 05-23-2011, 08:43 PM
jahummer's Avatar
Received 2,383 Likes on 1,493 Posts
Did it make a difference? I would assume that Alpine mated their amp to the specs of the subs (ohms, voice coil, etc). Just because they are the same size, does not mean they have the same power capabilities.
Old 05-23-2011, 11:58 PM
Jsedita74's Avatar
yeah if possible can you please list the specs? from my understand i thought there was 2 subs? i wanna get the max that the amps can handle . i dont want to strain the amp
Old 05-24-2011, 06:54 AM
Default Subs
I had absolutely no problem whatsoever with the KICKER 6.5 CVT SUB. It sounded better than the original speaker and played fine. No strain on the AMP, nothing at all.
I have pics in my Alblum of Audio stuff, no direct shots of that Sub, but you can see the Subwoofer holder right above the AMPS in my trunk, right next to the 10" Subwoofer, take a look if you like.
Old 05-24-2011, 11:31 AM
Jsedita74's Avatar
is there 1 or 2 subs back there? and how hard is it to replace? so its 6.5 inch and 4ohms... also do you know whats the max the amp can handle?
Old 05-24-2011, 05:40 PM
Jsedita74's Avatar
cant find much info on this system...
i wanna keep everything as stock as possible and upgrade the subs to the max possible without blowing anything out ... wish i knew the exact specs
Old 05-24-2011, 11:44 PM
Jsedita74's Avatar
Ok so to recap im looking for 2 6.5" subs ... At 4 ohms? Any particular wattage i should be looking for?
Old 05-25-2011, 06:30 AM
Default Subs
Sometimes it's hard to tell who you are talking to here, but here is the info in my opinion: Some Jags came with one Sub, some came with two Subs, mine had one. Yes, stay with the 4 ohm, that won't blow the stock AMP, something lower may damage the stock Amp. Don't worry about the wattage on the speaker, it won't matter, But keep it in Human specs instead of "SOUNDOFF COMPETITION" specs. Hope that helped.
Let me know how it all goes.
Old 05-25-2011, 01:01 PM
Jsedita74's Avatar
is there any way to tell if i need 1 or 2 before i run out n buy?
Jsedita74's Avatar
Old 05-25-2011, 01:10 PM
Jsedita74's Avatar
ok so i called the dealer and he confirmed there are 2 subs..... now time to pick something out..........
Old 05-25-2011, 05:20 PM
hlgeorge's Avatar
Oops!
Old 05-25-2011, 06:32 PM
Jsedita74's Avatar
I want plug n play items . Everything must stay stock.
Old 05-26-2011, 07:44 AM
Default Kicker subs
Yes that is the Sub I used, it worked great. And plug and play, yeah you can screw them in and when your finished with all, just screw out and put stock ones back in.
Be careful when screwing that Stock Sub box from under the rear deck, make sure you have something or someone to hold one side up while you unscrew the other side.
Old 05-26-2011, 08:19 AM
phd12volt's Avatar
my alpine subs were 2 ohm coils
scroll down on my link, and you can see the alpine part numbers and the measurement of the factory speakers
http://www.cardomain.com/ride/335898...-s-type/page-3
Old 05-26-2011, 08:29 AM
Default Subs
OK, I never saw anything on mine or in my car that indicated that they were 2ohm, and who would figure that a car manufactorer would use 2ohm loads in their Auto's, so no, I never would have tried 2ohm loads on that factory Amp.
Old 05-26-2011, 11:48 AM
Jsedita74's Avatar
phd those are not the same speakers as in our cars
Old 05-26-2011, 11:12 PM
Jsedita74's Avatar
anyone have instructions on installing these things on our cars?4444
Quick Reply: anyone know the subwoofer specs for the alpine car?
