Bleeding Brakes FAQ
Old 03-19-2011, 02:07 PM
DB6's Avatar
DB6
DB6 is offline
ud
Default Bleeding Brakes FAQ
Hi,
Does anybody have the proper Jag Shop book instructions on a brake fluid flush and bleed for an 04 XJ after a master cyl replacement?
Does the park brake have to be somehow turned off to do the rear calipers ?
I have had a local shop do this job but the pedal still feels a little spongier that it was, they are going to re-bleed , just wonder if there is something we are missing.
Old 03-19-2011, 03:04 PM
chadmc5c's Avatar
Default bleeding
I am planning on doing mine next month just to flush out the old brake fluid. I have a power bleeder I bought for aroun 60 bucks that makes it a one person job. The same master cyl res cover as on my BMWs. I also use ATE Blue brake fluid or gold when flushing so as to make sure all the fluid has been renewed. Look for the power bleeder on Ebay or at Pelican Parts on the web.
Pelican Parts - Product Information: PEL-0109
hth
Chad
Old 03-19-2011, 03:44 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Originally Posted by DB6
Hi,
The attached may help.
File Type: pdf
DB6 (03-19-2011)
Old 03-20-2011, 05:53 AM
Cadillac's Avatar
Thanks u102768 ,another FAQ in the making
flyrr100
09-29-2015 03:47 PM
xjrjag
09-24-2015 10:08 PM
swetnK
09-23-2015 10:49 AM
Doug S
09-23-2015 01:28 AM
wannajag
09-22-2015 08:29 PM
Quick Reply: Bleeding Brakes FAQ
