Silence the Beltminder chimes
I have finally discovered how to successfully silence the annoying Beltminder chiming!
Note, this does not silence the initial chimes after you start the engine without a fastened seat belt. This remains as a useful reminder but prevents the stupid chiming later, such as when you are driving into the long private driveway to park your Jaguar in the garage of your country estate![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
1. Ensure the front passenger seat is unoccupied.
NOTE: the next steps (2 to 5) must be completed within 60 seconds.
2. Turn the ignition to the RUN position (do not start the engine).
3. Engage the driver safety belt buckle and wait until the seat belt warning lamp extinguishes.
4. Unbuckle the driver safety belt buckle and wait until the seat belt warning lamp illuminates.
5. Repeat Steps 3 and 4 a further eight times.
6. When the driver safety belt buckle is unbuckled for the ninth time a single chime will be heard. The single chime is confirmation that the Beltminder feature has been disabled.
The Beltminder feature will remain disabled even after leaving the car until the above process (Steps 1 to 6) is repeated.
If you repeat the process the Beltminder feature will be reactivated.
Proven to work on a 2006 Jaguar XJ8 VDP
My battery went dead. After charging the battery back to 100%, I had a continuous chime in both forward and reverse motion. I disconnected the negative terminal on the battery for ten minutes. Then I touched the negative cable to the positive cable and this eliminated the chime. It also cleared all warning messages I had on my dashboard.
scooternva
20
09-27-2023 11:25 AM
