1950 mkv jaguar re-assembly
So as stated in the intro thread , here are some pix of the Jag described:
![](https://www.jaguarforums.com/forum/attachments/mark-v-x-420g-58/49487-1950-mkv-jaguar-re-assembly-img_5854_zps0e39700a.jpg?dateline=1375050870)
![](https://www.jaguarforums.com/forum/attachments/mark-v-x-420g-58/49488-1950-mkv-jaguar-re-assembly-img_5857_zps00da9acd.jpg?dateline=1375050870)
![](https://www.jaguarforums.com/forum/attachments/mark-v-x-420g-58/49489-1950-mkv-jaguar-re-assembly-img_5862_zps34c690f4.jpg?dateline=1375050870)
The body is in the metal shop , being the roughest part of the project. I will be working on the mechanical part as my friend works on the body. You can see the original re-built engine, and the blasted and painted chassis.
Very cool. It looks like it is coming along nicely! Unfortunately, I couldn't tell you the original color of the suspension parts. Mine is too far gone to tell. My guess is black, but I don't really know. Jaguar Heritage could probably tell you - Jaguar Heritage. Jaguar Classic Parts
Steve Croasdale (09-05-2013)
Csib , Mike , -Thanks-
I'll put up some more pix in a few day's , some minor progress.
I have to deal with the throttle shafts on the SU carbs , there is too much play , the bodies will need to be drilled and fitted with bushings and a new throttle shaft. This is not unfamiliar to me, having done it on S&S carbs for Harleys.
Thank you ,Steve
Thank you ,Steve
Received 9,008 Likes
Wonderful photos! The Mk V is one of my favorite Jaguars-that-I-have-not-owned. It was only meant as an interim model - combining the new-style torsion bar front suspension with the old school chassis, engine, and body styling. But Jaguar was surprised to sell 10,493 in all variants over the three year production run. Only 577 of the LHD 3.5 DHC version were produced. The DHC is a bit too valuable for my bank account, but I have had my eyes peeled for a nice saloon for years.
Mike thanks for that info.
I understand we are dealing with a rare and expensive car. The car is a complete and original example. We are endeavoring to keep to non-fatal assembly techniques and the like. Someone else will be able to take the car ,when we are done, and elevate it to the next level of finish.
Steve,
You probably know this already, but just in case...
The Classic Jaguar Association is the focused organization for Mk V and earlier Jaguars:
Classic Jaguar Association - CJA is a car club dedicated to the preservation and restoration of all classic Jaguar automobiles
Their forum doesn't seem to have much activity, but their membership would certainly be the store of knowledge on the Mk V.
Folks may not appreciate how much of a bigger restoration challenge the DHC represents - it's not just a Mk V saloon with the top removed. That's especially true of the body work, with many more aspects of classic, hand-work, coach building techniques compared to the almost all-steel saloon. There is a lot more wood in the DHC body work - the single piece of timber along the full length of the bottom sills (where the saloon has a more common hollow steel box section), the complex door framing all in wood, plus wood members running around the top rear of the body (per Paul Skilleter). Then there is the sheer complexity of the DH top itself. Hope you have a good body guy (with wood working skills)!
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Hi Paul,
My car is now in the stage that the frame was sandblasted and powder coated, engine and transmission and suspension rebuild. (see picture).
Im now in the process to restore the body. The tub is repaired and powder coated and I'm now restoring the wood of the doors. After that I will have all parts painted in the primary colour.
Still about 2 years to go I think.
Regards
Dirk
Regards
Dirk
