420g auxiliary carburetor leaking!
Hello folks, im having a problem with the auxiliary carb on the 420g. As soon as i turn on ignition, fuel pump kicks in and the aux carb starts pouring petrol from the needle and Into the 3 ports or bores On the top of the unit (Air intake?). I appear to be missing a triangular top plate that is mounted with the bolts on the needle assembly and partially covers the intake bores though i dont see how this would cause the profuse leakage of petrol? Any ideas where to go fron here?
1964Daimler
09-09-2015 11:20 AM
