Brake Fluid Bleeding - Jaguar MKIX
I am currently having issues bleeding my front brakes on my 1959 Jaguar MKIX. The rear brakes bled without an issues but the front brakes do not want to release any fluid. I am currently using a Griot's Garage One-Person Brake bleeder like the one in the link attached. I bought this bleeder since it is similar to the one used by the previous tech. Please let me know if you have any thoughts?
One-Person Brake Bleeder - Specialty Tools - Tools - Griot's Garage
Thank you.
Thank you.
Jagfixer, thanks for the advice. I originally started from the back two brakes and had no issues but I can't get any fluid to come out of the two front calipers. I took the car for a drive and tried re-bleeding the front calipers with no luck. You mentioned check the unions for blockages; how can I do that?
Loosen all unions one at a time just like bleeding a cylinder and retighten after bleeding. Will get you closer to where fluid stops. If a new master cylinder might bleed at cylinder, if no fluid at one point may have a cup installed backwards.
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
