Disappearing Brake Fluid - Jaguar 420
Hi All,
I've got a 1967 420 with power brakes. The mystery that I'm having is disappearing brake fluid from the reservoir that supplies the master cylinder. There are no visible leaks from the system, but I have to frequently fill up the reservoir. The brakes also seem to work fine. Does anyone have any ideas where my brake fluid may be going?
S-Type Owner (07-01-2019)
Thanks for your input. I was coming to the same conclusion (but no white smoke from the exhaust though). Either that, or someone has been sneaking into my garage and siphoning out my brake fluid! I'm going to get around to pulling it off and examining it. When I do, I'll post the results.
Hi Barry, thanks for asking. Yeah, the mystery was solved. Turns out, it was the master cylinder. Due to the backward-tilt alignment of the master cylinder, the fluid was leaking out the back, running down the pushrod, and then down the firewall behind the insulation. New master cylinder and all is ok now.
Hi, Christopher:
The OP already posted the solution to his problem back in 2014. That said, you might want to go to the New Members Forum and post an "intro" telling us about yourself and your Jaguar.
The forum can be found here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
HI, I realise my question is years out of date as you solved this back in 2014. I have a 1966 MK10 with exactly the same problem. My solution at the moment is to keep a small sponge under the servo to clean up the fluid and top it up regularly. So my question, where did you get the replacement master cylinder? The only one I've seen, if you can find them, are £800+. I have found that a Land Rover Series 3 m/cylinder is the same but you have to make a union for the front reservoir.
Thanks.
Thanks.
Thanks.
Thanks.
https://whitepost.com/brake-sleeving...ding-services/
They do excellent work.
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
