Fuel line from tank, Mark 9
Help! I have searched and searched and cannot find the copper fuel line that comes from the bottom of the fuel tanks. It has a unique flare fitting. I need two. I also have the tanks out and could braze in another part that would be more compatible, but thought I could try to get this and the nut that goes with them. Any leads?
Fuel line from bottom of tank to pump
Fuel tank fitting compression type unknown
If your fuel lines are leaking at the joints, or couplings, copper seals (of the correct size), together with a thorough cleaning/burnishing of the mating surfaces may solve the problem:
Amazon.com: VIS Copper Flare Gasket, 45 Degree, Flare Fitting , Fit 1/2"Tube OD, (Pack of 10) : Industrial & Scientific
jerry conner
16
08-26-2011 03:22 PM
