Jaguar MK5 1949 rear brakes
The Mark V was essentially an old-style body with the old (pre-war Standard built) engine but on the chassis designed for the Mark VII. The car was only made for about two years due to delays in production of the new Mark VII body shell, made by the Pressed Steel Company. As the XK120 also used this chassis but in a shorter version, the brakes are almost certainly the same as XK120 brakes. As the XKs are well supplied parts-wise, you shouldn't have a problem finding the parts you need.
Charlroi19
11-02-2015 06:43 AM
