Mk IX handbrake warning light switch location
Just acquired a Mk IX, the handbrake warning lamp does not work and I believe this because the switch has broken in the past and been removed. I found the switch (attached to a bracket) loose with some spares and I think I can repair it. However, I have looked along the car all the way from the handbrake right up handbrake calipers and I cannot find where the switch should be fitted. Can any Mk 8/9 owners out there help?
Thank George, I have tested the switch on the break fluid reservoir by lifting the filler cap and the warning light works. I have a parts catalogue and the issue I have is with the handbrake switch (part C.15270). I just can't find where to mount it on the handbrake handle. Don't suppose you have a photo of where it is mounted.
S-Type Owner (11-15-2019)
Rocky15
02-08-2016 04:31 AM
MJG
01-31-2013 05:55 AM
