Mk VII External Chrome Side Trim
Hi Guys,
I have a 1955 MkVII ‘M’, which is in need of a lot of love! It was originally a NZ car, which found its way to Queensland in the late 60s I believe. It was BRG with Suede Green interior. It is now cream, with the original interior which is shabby but serviceable. It has rust in the drivers side external edge of the bulkhead where it meets the bonnet. The rear fender and quarter panel where it meets the ‘C’ pillar is also rust, though I have a replacement body to poach panels.
Working on the door and bonnet external side chrome trim is still away off. But I do have a question. Does anyone know if the material is brass / cast / or stainless steel? Parts of it look pitted, which leads to think that they are cast, but they do have some weight to them so wonder if they are brass under the chrome or stainless. Either would be preferable as they my buff out. Any thoughts?
I’d be keen to know of any Brisbane based Mk VII owners that may be willing to answer questions from time to time…..
regards
Dan Moore
regards
Dan Moore
Stuff made of brass can normally be rechromed, with pitting filled with bronze or suchlike then polished, (I had it done on a Mark 2 I rebuilt in the 80s), but Mazak stuff is a real pain. Nowadays with 3d printing, it should be easier to reproduce old Mazak items, but whether anybody is doing so I don't know..
Received 1,081 Likes
Damoco
I suggest you get in touch with WIZARD CHROME at Narangba which is just north of Brisbane They have a method to repair Mazak which involves some chemical process to stop the corrosion followed by heavy copper plating to fill in the pitting and then re-chroming..I have had several parts of Jag Muzak repaired. eg MK1 tail light housings, MK2 tail light housings, Mk1/2 number plate/reverse light plinths. By the way it typically takes up to 2 months to complete the process.
They are not cheap but they are definitely very good.
Bill Mac
Bill Mac
S-Type Owner (03-14-2022)
Hi, I had a straight piece from front left door (is Brass) on a 58 Mk8 rechromed. Short Curved pieces on rear doors need replacing as they get dented. Priced replacement parts ex Uk from Worcester classic spares. Only Ł65 for new. Probably cheaper than beating out and rechroming. Great company to deal with. They ship Fedx and not expensive. Check their website.
Cheers D
Cheers D
Mark2rims
01-25-2019 02:37 PM
