MKX fuel tank banjo bolt size.
Hi, just hoping that someone out there is able to tell me the exact dimensions & thread pitch / gauge of the Banjo Bolts used to attach the submersible SU pump outlet pipe to the through tank attachment point. While I have a box of banjo bolts these ones seem to have been misplaced!
They are slightly longer than those used on the outside of the tank as the banjo fittings used in the tank differ slightly, so even if someone knows the thread details I can just source the correct length!
Thanks in advance for any assistance you can offer.
Thanks. I already ordered a couple of those previously but found they were too short. They certainly seem correct by the description but it seems the fuel pump to inside of tank requires a longer banjo bolt as these only end up with about 2 full turns of thread protruding through the banjo fitting and washers.
Thanks for your help so far.
Richard.
Richard.
