Mark V - X 420G 1948 - 1970
Reboring 3.4 to 3.8 litre
Old 10-20-2015, 02:30 AM
Devendra Singh's Avatar
Default Reboring 3.4 to 3.8 litre
Hi, I am restoring '52 Mark VII and want to bore to 3.8 litre.
I intend using the 87mm pistons. Do I need to change the head?
Also advice what all I need to change, Valves, bearings etc.
Regards,
Dev
Old 10-20-2015, 07:43 AM
Jagfixer's Avatar
3.8L has liners.
Old 10-26-2015, 03:36 PM
Fraser Mitchell's Avatar
Received 2,450 Likes on 1,948 Posts
I would not recommend doing what you propose. When the 3.4 was a current engine in the 50s, some people did what you propose and found the block cracked between the bores due to not enough metal being left after boring.
It was for this reason that Jaguar used thin steel liners when they developed the 3.8 litre engine, and some changes were made to the block as well.
adam699
12-23-2015 10:45 AM
bcucharternet
10-29-2015 08:48 AM
Carlos de la Flor
10-27-2015 04:29 PM
Mundrwood
10-23-2015 03:11 PM
Mike Beda
10-17-2015 09:58 PM
Quick Reply: Reboring 3.4 to 3.8 litre
