Wobbly rev counter.
DB48, to me it sounds like your new cable has some dried lubricant in it and that is causing it to stick a little. My advice would be to get your hands on a 30ml bottle with a needle attachment. Get yourself some 0W20 full synthetic oil and put that in the bottle. Then, with the cable removed from the car, pull the end of the cable a little bit to expose the inner cable and using the bottle with needle attachment, add some oil to the cable. You will probably need to add say about 5 ml of oil to get it to go the full length of the cable. This will help the cable glide inside the sheath and should even out the RPM issues you are seeing.
S-Type Owner (04-01-2024)
If the cable re-lubrication doesn't fix the problem then it may be an instrument problem.
The Mk1 tacho is a very simple device spinning a magnet against an alloy cup which is the same principle as older house electric tariff meters.
It is very simple to remove the tacho, clean the internal parts with a petroleum-based product and re-oil the pivots in the instrument with SAE 10 or sewing machine oil.
Been there, done that, many times.
