Rear seat removel
Sorry you will not get to the battery that way, you have a gas tank in the way and most people are unable to remove the tank the right way. If you have a master ( black head) key you should spray the lock with WD40 and give it a try. Do not force it and if it is a green key do not try it. You can go to this link and see places under the hood you can connect a battery or charger to get the trunk open. I hope it helps! http://www.gusglikas.com/AutoRepairTrunkPowerAccess.htm
