1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap
#201
#202
#204
#205
#206
lickahotskillet (03-13-2018)
#207
#208
#209
#210
TillyJon,
I just dream this stuff up - bonnet to bonnet - then search out a fabricator.
Doug,
Not sure how far up I will have to go to cover air filter/induction/carb. Photo shows the carb under a long level sitting from the cowl to the nose. a one inch spacer has been added, so more clearance has disappeared. Will know soon. Opening will be to the rear. Mating the bell housing to the block to check concentricity is next. They the engine will come home.
All,
Dyno video too large, sorry. Even tried zipping it - DNW. I'll have to add it to you tube then try adding the link.
Cheers.
Doug,
All,
Cheers.
#211
#212
Certifiable, Clyde - what was the wall thickness of the Chromoly on that cage? Looks like a low-rise intake would keep the lump under the bonnet - assume all that height is about flow and horsepower? Even with that it looks like you'll only be up a couple of inches, depending on the air filter assembly. I don't know much about these engines - do they make low profile plenums for carbs that you can duct to cold air? Look forward to your progress.
#213
#214
Doug,
The answer to all your questions would be yes. Would not have needed the intake, cam, & heads I picked and the hood would have closed easily at 500 or close to 600 HP.
The game plan was 700 + HP with a red line of 7500 on pump gas. Compression is 11.2:1. Best pull was 706HP at 7000. Torque from 4800 RPM is 600 ft lb through 6200 RPM. Need any trees removed?
As "they" say, it's all in what the heads can flow. Cam lift is .720", we backed it down a little from the original .750" suggestion of the head builder. Wanted to retain some of the bottom end power. The machinist kept saying don't worry about bottom end power - it has a long arm. Stroke is 4.25". All certifiable numbers.
A few pictures back I'm shining a light down the intake to the back of intake valve - pretty much a straight shot.
The carb builder said and I quote "I hope you know you'll have a handful". 980 CFM.
Thanks for all the comments & views.
#217
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x800/img_6330_dd75129d82f5f34a9e4408742bb68976f27877dc.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1449/img_6327_485c27b21704682e29ec1de9789c57bfa23ae9d7.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1156/img_6326_4fc7af2de2b7c2708e7351425310ee3a56afbf31.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1408/img_e6334_45f51b5342d90d1f531493eeec6d375b43659d84.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1660x2000/img_6328_c346bb8640ca19c1c102d6b4bcb2207a8340c516.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x985/img_6333_79eb377cae7d664a5cfa618719e19224ab4f0599.jpg)
AWOL for a while from here. I've been watching projects from my phone, although not the best venue.
Picked up four Nitto 555 G2's for my project.
275 x 40 x 17" on 9.5" rims for the rear
245 x 45 x 17" on 8" rims for the front
I'm pretty sure the spats are "out" for the rear. There are good clearances everywhere else,.
#218
#219
#220
Are you using it for burn outs or launch control ? (just working out which way the lunacy is heading !)
Just put a sliding door in the firewall, stepper motor operated of course, you can then have it thermostatically open for as much or little heat as you want from the engine bay, mind you with 700 BHP the pressure wave may blow the windows out, so you may need to link the stepper motor input to the electric window openers so avoid excessive pressure build up in the cabin !!
lickahotskillet (07-08-2018)
