1961 Mk2 3.8 Restoration
#121
#122
#124
#125
Unfortunately I have never welded, and I have no welding equipment. I know there are a few places on the body that will need to have metal replaced. Apparently I'll have to add this to the list :P
#126
I have finished installing locks (barrels) and I'm down to 2 keys. Essentially I got most of my information from the Jaguar Manual and a handful of inspiration from old(2013) entries from this forum. And I used copious amounts of PB Blaster(love that stuff!) Pics I took are mostly too dark and too close-up to distinguish but I will post what I did if requested.
csbush (03-20-2017)
#127
Last time I took the car out (weekend before last) my acceleration was horrible, it seemed to me that I had to rev very high to accelerate at all, and at the end of the drive I noticed my oil pressure was way down. Pulled over, and when I checked, oil was low.
Got me thinking that if I'm burning oil my compression might be down. So I checked that today. I doubt that I have done it completely right but here's what I came up with:
Cylinder
6 - 120
5 - 120
4- 150
3 - 150
2 - 140
1 - 145
Assuming these are good readings for a 3.8L how does this compression compare? What do you read into these numbers?
Cylinder
6 - 120
5 - 120
4- 150
3 - 150
2 - 140
1 - 145
#128
Gene
on those readings compression is down on 5 and 6 and a little low on 2 but not terrible, try the checks again to make sure you have correct readings, then you could try a leakdown test to try and isolate the issue, hear is a good article on how to perform this if you don't know.
https://mobiloil.com/en/article/car-...-leakdown-test
#129
#130
#131
Been about a month so I reckon I better let y'all know I haven't been a total slacker.
During the last month I have taken the car down to the shop that I want to do a lot of the interior and exterior work. They did the following:
- Tuned the engines and carbs. Their lead mechanic says the carbs "were not that bad"
- Replaced forward suspension bushings and shock absorbers
- Replaced leaky heater valve
Went to a local tire place
- Replaced 40(?)-yr-old tires
And this past weekend I personally changed the differential gasket and diff oil
I'm talking with a transmission shop about fixing my automatic transmission. It works, but it lags a bit more than I want.
csbush (04-25-2017)
#132
#133
Thank you for the invite though. It helps to motivate me
#134
#135
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
Progress: Last night I pulled out the wooden dash (two 7/16 nuts and a light) and the after-market tape deck someone installed in the 80s.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20170426_oldtapedeck_6384ce54b5cd0507fb68d1c518d678486b7c0e1f.gif)
#136
Mile 47917 - Yesterday I drove down to get my fire extinguisher inspected/recharged, then drove over to ascertain what size wheels/rims I will need to order(I need 15x5 wheels). Then I drove a box of parts that I'm not likely to use for a while down to storage.
She did well, but my oil pressure gauge showed low pressure as the engine got hot. Everything else seemed fine for short trips.
#139
#140
