1961 Mk2 3.8 Restoration
Old 05-05-2017, 06:46 AM
csbush's Avatar
I hate to dip my toe into the tar pit of discussions on oil preferences, but I agree with Jose on Castrol 20W50. I use it in a number of older engines I have and am very happy with how it has been working. The one recommendation I have is to substitute one quart of the Castrol with a quart of Valvoline Racing Oil 20W50. It adds just enough anti-wear additive (ZDDP) to protect our engines.
The following 2 users liked this post by csbush:
gene61jag (05-05-2017), Jose (05-05-2017)
  #142
Old 05-05-2017, 09:39 AM
gene61jag's Avatar
This explains so much. It's good to discover/address this issue now rather than while I'm on a longer trip. All advice is welcome. Thank you all.
  #143
Old 05-06-2017, 12:45 PM
lickahotskillet's Avatar
Castrol current 20w50 is "SN". This is not your fathers 20w50. It doesn't not have the additive pack for solid lifter flat tappets. A quart of something that is additized with ZDDP will mix, but it is only a guess if it is enough. A additive bottle of ZDDP might be a better guess. First best choice is a oil with enough ZDDP by design for solid lifters. I believe the spec is "SG". Unfortunately, Castrol is not in the "old car game".
Me: ten years in the Castrol division of BP, and still waving the flag high.
  #144
Old 05-06-2017, 01:29 PM
Jose's Avatar
Received 2,443 Likes on 1,838 Posts
ok, so which 20W50 oil is good ?
  #145
Old 05-06-2017, 01:50 PM
TilleyJon's Avatar
Clyde, doesn't the Castrol Classic 20W/50 do the job ? It's SF spec and the literature says it should, but I can't find the ZDDP ratio's for it.
Millers classic 20W/50 is highly talked about here in the UK too, but I can't find the spec for that either other than it SJ spec.
What happens when an API classification become obsolete, it doesn't say on the API website, it just seems to get superseded by the next one ?
  #146
Old 05-06-2017, 02:10 PM
Jose,
Some 20w50's will say "meets SG" on the label, some will say additized with ZDDP for solid lifters or flat tappet cams.
From there, we get into "personal preferences", brand loyalty, and works great in my car.
I am currently using "Brad Penn Penn Grade 1 - 10w40 in my '77 XJ12L, engine is new with hydraulic roller cam. They also make various grades and carry endorsements of various cam manufactures.
20w50 is great to take up for wear and oil consumption. It is also what was used "back in the day" in a lot of muscle cars and sports cars. I've cut consumption, raised oil pressure, and quieted engines with 20w50.
Not a great idea for colder weather start ups.
https://m.summitracing.com/search/pr...de-1-motor-oil.
Next engine I'm building will have a solid roller. I am still searching what is out there in the shelf.
  #147
Old 05-06-2017, 02:15 PM
TilleyJon.
Yes on Castrol Classic. I Could not find it on the current Castrol USA Website. I may have not looked hard enough. I'll look again.
  #148
Old 05-06-2017, 02:23 PM
I looked again. It looks like it was pulled from the US marker.
  #149
Old 05-06-2017, 02:25 PM
Exactly in the obsolete. However label will say "meets", but not use the word "approved". Small detail.
  #150
Old 05-06-2017, 03:17 PM
TilleyJon's Avatar
god damn minefield !!
Guess it's down to doing the research and checking the details.
Thanks Clyde for that useful info, at least I can get Castrol and Millers here in the UK, I think Penrite do a good classic oil, but it's not readily available here, Australian product, not sure how available it is in the US
  #151
Old 05-07-2017, 11:10 AM
gene61jag's Avatar
Well this is what I bought yesterday. I didn't see a specification. Hopefully I won't kill my car.
  #152
Old 05-07-2017, 01:18 PM
TilleyJon's Avatar
What you have to look out for is that modern oils have high levels of detergent, these can wash the rope- graphite - asbestos seals and they can start leaking. It also washes the pistons etc., and can cause pinking.
The Castrol GTX most probably falls into that category, the Valvoline being synthetic is probably just as bad.
In 2015 GTX was at a standard for API SG or earlier, as of last year it has jumped to SL or earlier spec. (that is from the data sheets, but the website says SG or earlier!!) Most older engines, if not reconditioned with newer seals etc do not like later spec oils as they don't agree with the high additive content.
Valvoline high mileage does have added zinc which does not show on the Castrol spec. but does have higher detergent levels and is although it is SN spec on the face of it is better than the Castrol.
What you do with this information I am not sure, the subject of oil is a minefield, with the oil manufacturers advertising not necessarily giving you all the information.
  #153
Old 05-07-2017, 04:00 PM
gene61jag's Avatar
Aw crud, I totally missed where it said "synthetic blend" right on the front :P I saw where it was for cars over 75K miles and thought I was fine.
And I read where the Castrol said "sludge protection" and thought that was good. I did not see it as "High detergent"
Minefield is right! What do I look for?
  #154
Old 05-07-2017, 04:39 PM
Mineral, blend, synthetic, are not the issue. It's the missing ZDDP. Levels were lowered so cats would live 125,000 miles.
Detergent high in all new spec oils. Wash the seal, likely. Clean the pistons, maybe over time, cause ping, I doubt that one.
  #155
Old 05-07-2017, 04:40 PM
Grab a bottle of some ZDDP additive, & "run whatcha brung".
  #156
Old 05-07-2017, 05:01 PM
gene61jag's Avatar
Where do you get ZDDP additive Clyde? I didn't see any in the car store I went to yesterday. Or do I have to ask at the counter? If they blink twice instead of answering I just need to go to the next place?
  #157
Old 05-07-2017, 05:23 PM
Advance auto parts shows rislone with zppp. ORileys shows hyper lube with zinc replacement. After that, summit racing, Eastwood, amazon.
TilleyJon (05-08-2017)
  #158
Old 05-07-2017, 07:19 PM
gene61jag's Avatar
Sigh. I wanted to get the oil changed this weekend, but I want to do the best for the car.
It's been a good weekend to catch up on house and yard stuff instead.
  #159
Old 05-08-2017, 12:35 AM
TilleyJon's Avatar
Go with Clyde's guidance, I am not familiar with what's available stateside.
I have to correct my wording, it's the washing of the pistons, and the resultant build up of metallic ash is the chambers and crowns that causes the pinking, not the actual washing itself, this is only an issue on high oil consumption engines where the oil is passing into the chambers.
  #160
Old 05-08-2017, 12:52 PM
gene61jag's Avatar
Chuck, Clyde, Jose, Jon (Sorry if I've left anyone else out), I'm deeply humbled and ingratiated to you all for your concern for my car. It's obvious that you all want one more of these "rolling works of art" to be on the roads. I am just a hack; I will heed your advice.
I will do my best to do my part to get mine running well, and keep her purring. And, of course, I will keep you all updated. Now, I'm off to a car parts store(or 2)
Quick Reply: 1961 Mk2 3.8 Restoration
