1963 mk2 & 1957 Salon Parts Alert - Links
GGG and/or other moderators:
I've read in some of the posts that members wanted me to post any posts for parts I may come across. So if this is a violation of board policy, though I'm told it is not, please remove the post and inform me.
Disclaimer: I do not know these posters of parts nor have ever met them. This is just FYI per member request.
1957 Salon
Jaguar
Quote: When you see the picture , you will know if it is the year your looking for.....Car is in pretty bad shape,but like any older car the value is in what you can not get anymore.Let me know if you have a interest, we can go from there.?
1963 MK2
1963 jaguar mk2 parts
Quote:
we are selling various parts from a 1963 jaguar mk2 sedan ;
New modern radiator $550
Complet center dash assembly , all instrument gauges , speedometer , tachometer with working oem clock , some exterior chrome trim , metal head linner bows ,
Complet correctfactory tool kit $900
various tools for the factory tool kit , oem factory jack crank ratchet handle " king Dick "
used lucas generator the power steering type , a drive dog and a power steering pump
used voltage regulator
starter motor
carburator choke solenoid houseing , carburators
dash switchs
rear interior lights
new o.e.m. brake pads
interior chrome oem door handles
lucas fuel pumps
exterior chrome windshield squirter o.e.m. N.o.s. lucas upper fender red plastic back lighted corner markers
ignition switch with matching numbered key oem
Two headlight dash switchs three and four ( fog light) position types
Two chrome wire wheel knock off need rechomeing $20 each
complet drivers side left front door chromed window frame assembly ,
rear red upper and lower plastic tail light lens new engine air (pancake) round oem air filter
new brake and clutch hydralic flex lines
new clutch slave cylinders short and long type two metal " county placards " for display mounting on the bumpers or radiator grille one Germany one Philippines .
A few exterior chrome body finishing pieces .
New Front windshield gasket
Four oem Dunlop 72 spoke chrome wire wheels some with tires some without tires $125 each
if not listed above , i do not have it please do not ask for it.
priced lower than any others but not by a lot.
1957 Salon
Jaguar
1963 MK2
starter motor
dash switchs
lucas fuel pumps
Scott B
10-24-2015 01:29 PM
Dicque
09-19-2015 12:53 PM
