1964 MK2 steering column
I cannot find a parts book drawing of the steering column in my MK2. I am referring to the end portion which bolts to the firewall. I would like to know if there are any rubber gaskets or seals. Especially where the auto trans selector shaft exits the firewall.
This part was not fully installed in my car when I purchased it, I have little to go on.
I will post a photo.
Bob
Bob
There will definitely be a seal and probably a grommet for the autotranny shaft. Most times a standard grommet will fix the tranny shaft, but the seal for the large plate in your photo is likely a flat piece of rubber, maybe moulded maybe not, but anyway, you could probably make up your own if you can find the sheet rubber to use. I doubt these things are available anymore, but you could try contacting SNG Barratt. They have a USA office
SNG Barratt - The Ultimate Jaguar Parts Specialist
rdssdi
10-24-2015 02:52 PM
